That's not a USB or Firewire or HD Audio header plug as there aren't enough wires, except for a single USB.
It's also not a Serial port header for a COM port as the indexing nubbin is on the same side as the blind pin.
It could be an AC97 plug that leads to the front audio jacks of the case.
Are you sure that's where the wire leads to?
