Need motherboard and CPU for under $100
Lethalcube
31
I need a motherboard and CPU under $100. I already have everything else and just need a motherboard and CPU . My budget is really tight so if you have to go over please do not go over by a lot.
Ideally you want at least a hyper-threaded dual core CPU, or you may find that even a 750Ti will get bottlenecked, but as far as Pentiums go its not a bad one. Seriously, I'd really consider 2nd hand as you will get much more bang for your buck that way, albeit without the warranty safety net.
I already have a GPU (GTX 750TI EVGA) and all the other parts. I was thinking about getting an Intel Pentium G3258 and the motherboard is a MSI MATX Motherboard H81M-P33, but I am not sure if I should get them
