need motherboard manual
Inoidea
18
hello does anyone know where I can get a manual for my uATX IPMMB-FM Pegatron Intelz75 LGA 1155 motherboard.I've searched the internet but no luck as of yet.Motherboard size is 9.6in by 9.6 it came in a hp h81455pc.i installed it into a new case and need to double check all the connections, my pc now wakes up a lot and 2 of my usb 3.0 do not work.Thanks for any and all replies
yes I believe you are correct I've been all over the net and cannot find one, I did find a connection diagram for F_panel on hp forum site and used it . thanks for your reply
