Need Motherboard Suggession for my CPU Intel E5 2673 V4
Dec 27, 2018
13
Exactly what the title says. I Need Motherboard Suggestion for my CPU Intel E5 2673 V4. Budget around $600
Thanks.
I have ASUS Z10PE D16 WS
https://www.asus.com/us/Motherboards/Z10PED16_WS/HelpDesk_CPU/
Unfortunately as you can see it doesn't support this CPU. Any Mobo that will support my CPU?
Thanks.
Notice how much information is missing on that row compared to the others. Especially the cost. That was a CPU that Intel made for some specific market, maybe Amazon or some other large datacenter. If it isn't listed in the ARK, then it wasn't intended for general sale. I don't know if you will find a motherboard that supports it.
What happens with that Asus motherboard ?
http://www.tomshardware.co.uk/answers/id-3854010/build-showing-system-initializing-error.html
Please review.
If both of your CPUs have the same problem when installed in the first CPU socket, then you have an incompatibility. All you can do is contact Supermicro or Gigabyte to see if thay have any motherboards that will support. These are the hazards of buying "cheap" used Xeon CPUs.
I have only one CPU installed. Seller says he is using Supermicro X10DAI and MSI X99 to test his products. Should i go with Supermicro X10DAI?
Thanks.
Prompt advice. Also do you have any advice to test the system one last time. I did BIOS update:
https://www.asus.com/us/Motherboards/Z10PED16_WS/HelpDesk_BIOS/
Do i need to update any specific BIOS version Or maybe change the bios chip? Any suggesion for bios chip like below:
https://www.ebay.com/itm/BIOS-CHIP-for-ASUS-Z10PE-D8-WS-Z10PE-D16-WS-Z10PH-D16-KGPE-D16/142108296109?hash=item21165083ad:g:WaQAAOxyFXhSNrEM:rk:4😛f:0
Current Issue:
On board Q-Code 67
CPU DXE Initializing
Thanks.
No i have not what to do with that port? Any advice.
