Need new power supply.
Jianni123
93
Hi everyone.
I need a new power supply since I may be adding another GTX 680 soon and I don't trust my 750W Powercool to handle it.
I was looking at the 760i from corsair but I don't know if it has all the right connectors that I need since I'm abit confused with all that. Also any other recommended PSU would be helpful.
Semi Modular or Fully Modular power supplies please. Do the fan connectors come with the power supply? I will be overclocking. CPU will be at 4.4/4.5GHz.
With slight GFX overclock.
My build is as follows;
CPU- Intel Core i7 3770K
Motherboard- Gigabyte UP5-TH
Ram- Corsair Dominator Platinum 16GB 1866Mhz
PSU- Powercool 750w Black 80 Plus (needs upgrading)
GPU- EVGA GTX 680 Signature 2
Case- Coolermaster Haf 922
HDD- 1TB WD10002FAEX Caviar Black
Drives- 2 DVD Drives.
SSD- 128GB OCZ Agility 4
CPU Cooler- Corsair H100
Fan Controller- Aerocool Touch 2000
Wireless Card- GC-WB300D
Extras- Front Red Led Fan, Side Red Led Fan. 120mm at back and bottom of case.
Thanks
edogawa
Splendid
Jan 4, 2012
2,891
264
The Corsair Ax760i will be an excellent power supply, corsairs new digital power supplies are top notch.
I do have some serious concerns about your build though. What will it be used for?
Gaming and encoding?
edogawa
Splendid
Jan 4, 2012
2,891
264
That's way overkill.
asalikus
616
16
You can power a $7000 build with that...
edogawa
Splendid
Jan 4, 2012
2,891
264
The corsair one he selected is fine, it's a seasonic built one with digital features, I have the 860i version, and it's fantastic unit.
It's 189 on newegg right now after a rebate.
obsidian86
Splendid
Aug 5, 2009
5,762
166
the corsair I models are flextronics built
edogawa
Splendid
Jan 4, 2012
2,891
264
My bad, I didn't know they switched the AX series to flextronics, very good power supplies regardless.
ko888
16,530
8
97,165
3,087
For a system using two GeForce GTX 680 graphics cards in 2-way SLI mode NVIDIA specifies a minimum of a 750 Watt or greater system power supply that has a maximum combined +12 Volt continuous current rating of 53 Amps or greater and that has at least four 6-pin PCI Express supplementary power connectors or two 6-pin and two 8-pin PCI Express supplementary power connectors depending on brand and model of the graphics card.
Total Power Supply Wattage is NOT the crucial factor in power supply selection!!! Total Combined Continuous Power/Current Available on the +12V Rail(s) rated @ 45°C - 50°C ambient temperature, is the most important factor.
Overclocking of the CPU and/or GPU(s) will require an additional increase to the maximum combined +12 Volt continuous current ratings, recommended above, to meet the increase in power required for the overclock. The additional amount required will depend on the magnitude of the overclock being attempted. Since your CPU overclock is below 4.6 GHz there's no need for an additional increase to handle it unless you need to tweak/increase the CPU's core voltage to achieve your overclock.
Corsair AX760 760W Full Modular Power Supply (CP-9020045-UK)
• OEM: Seasonic
• maximum combined +12 Volt continuous current rating of 63 Amps
• six (6+2)-pin PCI Express supplementary power connectors
• 80 PLUS PLATINUM Efficiency
• 7 Year Warranty
http://www.scan.co.uk/products/760w-corsair-ax760-full-modular-80-plus-platinum-92-eff-eps-12v-sli-crossfire-1-x-120mm-fan-atx-psu
Corsair AX760i Digital 760W Full Modular Power Supply (CP-9020036-UK)
• OEM: Flextronics
• maximum combined +12 Volt continuous current rating of 63.3 Amps
• 7 Year Warranty
http://www.scan.co.uk/products/760w-corsair-ax760i-digital-full-modular-80-plus-platinum-92-eff-eps-12v-sli-crossfire-1-x-120mm-atx
XFX Pro Black Edition 750W Full Modular Power Supply (P1-750B-BEFX)
• OEM: Seasonic
• maximum combined +12 Volt continuous current rating of 62 Amps
• four (6+2)-pin PCI Express supplementary power connectors
• 80 PLUS GOLD Efficiency
• 5 Year Warranty
http://www.scan.co.uk/products/750w-xfx-pro-black-edition-p1-750b-befx-full-modular-80-plus-gold-90-eff-eps-12v-sli-crossfire-1x120
Seasonic Platinum 760W Full Modular Power Supply 80+ Platinum (SS-760XP2)
• OEM: Seasonic
• 7 Year Warranty
http://www.scan.co.uk/products/760w-seasonic-platinum-ss-760xp2-full-modular-80-plus-platinum-92-eff-eps-12v-sli-crossfire-atx
Seasonic X-Series 750W Full Modular Power Supply 80+ GOLD (SS-750KM3)
• OEM: Seasonic
• 7 Year Warranty
http://www.scan.co.uk/products/750w-seasonic-x-series-ss-750km3-full-modular-80-plus-gold-87-eff-eps-12v-sli-crossfire-atx
Corsair HX 750W Professional Semi-Modular 80 PLUS Gold Power Supply (CP-9020031-UK)
• OEM: CWT (Channel Well Technology)
• 7 Year Warranty
http://www.scan.co.uk/products/750w-corsair-pro-series-gold-hx750-modular-psu-80-plus-gold-sli-crossfire-eps-12v-atx-v231
Jianni123
93
1200W is overkill for me. I would never use that much, the 760i is about the sweet spot for me since its platinum power efficiency too.
On your PSU did it come with moles adapters too plug your fans into?
Also I'm in UK so I can't use newegg but I will look for a alternative.
Jianni123
93
That will probably be my choice of PSU.
Seems good enough.
Gaming mainly and some video editing, picture editing etc.
Jianni123
93
Thankyou for this. It helped a lot in understanding power supplies and what to look for, is the 750W combined system wattage or just SLI wattage?
The graphic card requires one 6 pin and one 8 pin.
My CPU and GPU are overclocked too. With a 4.5GHz OC at 1.23V.
The power supplies you recommended are great, and I also live in UK so thank you for that.
ko888
16,530
8
97,165
3,087
The 750 Watts is for all of the components in the computer case including the graphics cards.
I was able to deduce that you reside in the UK from your Powercool PSU since they only seem to be sold there.
Jianni123
93
Surely 750W is not what it will actually pull on Full load though?
The PSU was a quick decision due too dad not willing to pay around £100 for a 750W-.-
I love Corsair Power Supplies. XFX seem to be pretty good. Seasonic, Antec, EVGA. All seem to be good choices.
ko888
16,530
8
97,165
3,087
750 Watts is a power supply capacity recommendation. It is not the system's power draw since that would be less than 390 Watts when using one GeForce GTX 680 and less than 555 Watts when using two GeForce GTX 680 in 2-way SLI mode.
You would never run a 750 Watt power supply at a full 750 Watt power draw continuously for any extended length of time because it would be doubtful that it would survive for very long.
Jianni123
93
Thankyou. Sorted my confusion out, personally Im leaning towards the 760/760i from corsair. That will no doubt be a good enough power supply. Also since im putting new fans in, replacing the old ones all I have to do is plug them into the same slot. correct?
ko888
16,530
8
97,165
3,087
If the new fans have same connector type and same mounting method then it should be a direct swap with the old fan.
Similar threads
