[SOLVED] Need new power supply
mojo-cutter
22
Need new PSU
My PSU just broke, so I need a new one.
My PC
motherboard: Gigabyte GA-B150-HD3P Intel B150 So.1151 Dual
RAM: DDR4 16GB (2x 8192MB) Crucial CT2K8G4DFD8213
Processor: Intel Core i5 6500 4x 3.20GHz So.1151 BOX
Graphics: onboard
HD: SSD 250GB Samsung 750 Evo 2.5" (6.4cm) SATA 6Gb/s and 500GB Samsung 850 Evo
my old PSU: xigmatek go green nrp-PC 502, 80 plus bronze , 500W
any suggestions? (price up to € 120,- )
Hey there,
I'd go for any of the following : Corsair RM/RMX/RMI/TXM. Seasonic Focus Plus Gold, EVGA G2/G3. They are all quality units, with long warranties, that will last through to your next build.
Your system , without a GPU, will not be pulling in much wattage at all. If you plan to get a discrete GPU then the 500w might be good option. Alterntively, if you arne't going with a dGPU, then something small will do fine. Maybe 400-450w.
Where are you purchasing from? You should be able to get a Corsair RM450w (good psu) for under €120 easy.
Hey there,
https://www.amazon.de/dp/B07VQX7VG8?tag=pcp05-21&linkCode=ogi&th=1&psc=1
Can't go wrong with either the RMx or this one, both performs really well and are very quiet. But I prefer this one as it has Platinum efficiency instead of Gold.
You can also get one of these which is a bit cheaper:
https://www.amazon.de/dp/B07TJYNGB8?tag=pcp05-21&linkCode=ogi&th=1&psc=1
Reactions: Roland Of Gilead
That Fractal is nice! Good spot 👍
Reactions: refillable
