Question Need new system, help please
Pghkevy
37
Can someone help me build a system for under 1200, does not need to be a gaming system. I AM NOT A GAMER! repeat NOT a GAMER don't need the latest and greatest graphics card for games.
Approximate Purchase Date: 2 months
Budget Range: (e.g.: 300-400) $1200
System Usage from Most to Least Important: 3d rendering ( i run a cnc router, the 3d rendering on my current system takes ages) surfing net, watching movies
Are you buying a monitor: NO
Parts to Upgrade: (e.g.: CPU, mobo, RAM)Need everything but PSU, monitor keyboard case and mouse.
Do you need to buy OS: Yes
Preferred Website(s) for Parts: newegg
Parts Preferences: NO preference
Overclocking: NO
SLI or Crossfire: doesn't matter
Additional Comments: would like something that will last several years , Would like a mobo that has the most sata ports or a hdd enclosure possible, and Psu with the most sata power cables.
And Most Importantly, Why Are You Upgrading: Upgrading because my system is to slow for 3d rendering applications
Thank you in advance for your help
I would say something like this:
Intel iGPU for Quick sync in adobe programs
Nvidia gpu with 16gb VRAM for rendering
PCPartPicker Part List
CPU: Intel Core i5-12600K 3.7 GHz 10-Core Processor ($183.45 @ Amazon)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler ($35.90 @ Amazon)
Motherboard: ASRock Z690 Pro RS ATX LGA1700 Motherboard ($119.99 @ Amazon)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($54.99 @ Amazon)
Storage: Acer Predator GM7000 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($129.99 @ Amazon)
Video Card: PNY VERTO GeForce RTX 4060 Ti 16 GB Video Card ($449.99 @ Amazon)
Case: Phanteks XT PRO ULTRA ATX Mid Tower Case ($69.99 @ Newegg)
Power Supply: SeaSonic FOCUS GX-750 ATX 3.0 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($89.99 @ B&H)
Total: $1134.29
Generated by PCPartPicker 2024-04-23 02:11 EDT-0400
Reactions: Why_Me
What software are you using? Blender?
Just something I quickly slapped together based upon your description, and assuming Blender use. You could probably improve upon the list with more research/fiddling.
https://pcpartpicker.com/list/bRFNwg
References:
Puget 13th gen Intel / 7000 Ryzen CPU comparison
Puget RTX4070/4060Ti comparison
Vcarve pro and aspire. and thank you ill check it out. Vetric programs on this pc, when 3d rendering, take so long i can go set up my job material, and still have time to take a break or eat or sleep LOL
Cheers. I’m not familiar with Vectric but did a bit of searching for info on its system requirements/usage. Very hard to find definitive comparisons. Found this forum post and this one. Sounds like it will use as much CPU performance as possible, but can accelerate with GPU for renders if it’s set up to do so in software via OpenGL. The official site is pretty vague on system requirements.
What‘s your current computer and its specifications?
Intel Core i5 7th Gen - Core i5-7600K Kaby Lake Quad-Core 3.8 GHz LGA 1151
ASRock Z270 TAICHI LGA 1151 Intel Z270 HDMI SATA 6Gb/s USB 3.1 ATX Motherboards - Inte
G.SKILL Flare X Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) AMD X370 / B350 Memory (Desktop Memory) ...
windows 10
The Vectric user forum might be a better place to ask specific system build questions. You might have specific needs based upon your 3D model sizes and software version.
The other uses you mentioned would be pretty well covered regardless, even by the contemporary ‘low end’. Good luck 👍
Reactions: Lucky_SLS
