Need Opinion On Temps And Voltage FX 6300 GTX 960
jojam88
Commendable
Oct 6, 2016
is it safe for this to stay like this(picture) ? i have an fx 6300 and gtx 960 ssc. Just wondering, cause i get no crashes or problems, is the cpu voltage and temps good? I dont wanna OC too much im just on stock cooler. thanks guys. http://imgur.com/gallery/Rap2w
4.1 GHz should be safe on the stock cooler with those temps. It doesn't look like you increased the CPU voltage. And the GPU temps are fine.
You might not be getting much performance boost @ 4.1 GHz, since the turbo mode is that much anyway. Granted, it is with less than all 3 modules in use. But with most games, they may not be anyway.
