Need opinions and suggestions on my build
djthiago1
38
I'm actually looking to reduce the price a little, as my budget is a bit tight, any suggestions on better parts and/or cheaper ones would be welcome, preferrably with little performance loss to none.
On my cart i currently got:
HDD
Seagate Barracuda ST1000DM003 1TB http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
MOBO
GIGABYTE GA-970A-UD3P AM3+ http://www.newegg.com/Product/Product.aspx?Item=N82E16813128651
GPU
EVGA SuperClocked GTX 770 2GB http://www.newegg.com/Product/Product.aspx?Item=N82E16814130921
PSU
SeaSonic S12II 620 (620W) http://www.newegg.com/Product/Product.aspx?Item=N82E16817151096
RAM
G.SKILL Ares Series 8GB (2 x 4GB) http://www.newegg.com/Product/Product.aspx?Item=N82E16820231544
CPU
AMD FX-8320 http://www.newegg.com/Product/Product.aspx?Item=N82E16819113285
Hey,
It's almost similar to my build, so I'm saying it's a very good build, you can do any game on Max Settings, your GPU is the best on the market at the moment as in Performance/Price value, and everything is compatible. Your PSU is from a great Manufacturer, that's great 'cause a PSU is important.
But you asked for suggestions too, and I have only 1, 'cause it's already a good build, here is my suggestion:
For the RAM, go with GeIL EVO POTENZA 8GB (2 x 4GB) DDR3-2666 as it's super fast and reliable, and for a gaming PC, that matters.
Here are some sites to help you out:
- Pcpartpicker.com
- http://www.anandtech.com/bench/product/770?vs=854
- Futuremark.com
If you want you can check out my build too:
CPU: AMD FX-6350 3.9GHz 6-Core Processor ($139.99 @ Amazon)
Motherboard: ASRock 970 Extreme3 R2.0 ATX AM3+ Motherboard ($64.99 @ Newegg)
Memory: GeIL EVO POTENZA 8GB (2 x 4GB) DDR3-2666 Memory ($89.99 @ Newegg)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive ($50.74 @ Amazon)
Video Card: MSI GeForce GTX 770 2GB Video Card ($359.99 @ SuperBiiz)
Case: Zalman MS800 Plus ATX Mid Tower Case ($79.99 @ Newegg)
Power Supply: SeaSonic 620W 80+ Bronze Certified Semi-Modular ATX Power Supply ($91.98 @ SuperBiiz)
Optical Drive: LG GH24NSB0 DVD/CD Writer ($15.99 @ Microcenter)
Total: $893.66
(Generated by PCPartPicker 2014-01-19 11:59 EST-0500)
Hope it helped! :)
Here change these parts for the cheaper ones :
1.CPU : AMD Fx 8320 Same thing - $25 cheaper
2.Mobo : BIOSTAR TA970 Better performer - $30 cheaper
3.GPU : Gigabyte GeForce GTX 770 OC Same thing, different Brand - $30 cheaper
4.PSU : Stick with Seasonic, its the Best
5.RAM : Kingston Hyper X Blu 8 GB (2x4GB) Almost same thing, different brand - $7 cheaper
6.HDD : Same price everywhere..
Soo all in all u can save upto $92 .. select it as the Best Answer if u found it helpful !
