Try this build. I took you from an H110 to an H170 mobo, much better and more features/connectivity. The ram is faster with higher MHz and lower CAS. Changed the PSU to lower wattage but better quality, you don't need 650W. The storage is equivalent speed/quality but a little lower price. The case has more storage but you will have to remove one of the cages to get the video card in. But after this you will still have more storage spots at a cheaper price. You end up with a $15 increase but I think a better build.
PCPartPicker part list:
http://pcpartpicker.com/p/RbznYJ
Price breakdown by merchant: http://pcpartpicker.com/p/RbznYJ/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($199.98 @ OutletPC)
Motherboard: ASRock H170M Pro4 Micro ATX LGA1151 Motherboard ($82.98 @ Newegg)
Memory: Mushkin Redline 8GB (2 x 4GB) DDR4-2400 Memory ($52.99 @ Newegg)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive ($38.99 @ NCIX US)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($45.88 @ OutletPC)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card ($269.99 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case ($47.99 @ Micro Center)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($55.99 @ SuperBiiz)
Total: $794.79
Generated by PCPartPicker 2016-01-25 15:43 EST-0500
