hey guys,
im making this thread because I am very unsure what to do about my computers cooling options.
its the classic water cooling vs. air cooling...
So for watercooling I would be going with these parts:
Case: Fractal design ARC XL
Fans: 2x corsair AF140
3x corsair SP120
Cpu: i5-4670k
Gpu: MSI reference gtx 760 (Watercooled and planning to overclock highly)
mobo: MSI Z87 G45 gaming
RAM: corsair vengeance 8gb
storage: WD 1tb caviar blue
*Psu: corsair builder series CXM 750w*
Pump and res: XSPC X20 pump V4 with dual drive bay black
CPU block: EK supreme LTX CSQ Copper Plexi
GPU block: EK FC670 copper plexi
Rad: Alpha cool NexXxos XT45 (360 triple 45mm deep)
Liquid: Mayhems X1 clear and Mayhems UV green dye
Note:*the psu I am really not sure about, a friend suggested it to me. what do you guys think? will it be good enough?*
In total the cooling system on that is about £270 or $435 USD
removing this watercooling system, adding 2 more fans for the case ,including £60 for a good air-cooling heat sink and possibly 2-3 more fans depending on the heat sink the cost difference is around £150 or $241
This extra money I could spend on better Gpu, cpu, storage etc
so basically:
1) which option would offer the best price/performance ratio (assuming both cpu and gpu are overclocked)
2)What cold I spend the extra £150 on?
3) What do you personally think I should do? considering I have gone with the reference gtx760 I have a feeling I will be spending most of the extra money on making that better... or should I get a completely different card?
Currently im leaning towards the liquid cooling because im not too sure how much extra performance the £150 will give me in comparison...
I will be using my system for gaming such as BF4, Destiny, Ksp, Gmod, Arma3 etc...
Any suggestions for parts are very welcome, I want this build to be perfect 😛
Pretty much, my decision is to put the money into watercooling and upgrade the parts later, or put the money into the parts and upgrade to watercooling later...
I Really need the help on this one guys, thanks for any input!
3x corsair SP120
Cpu: i5-4670k
so basically:
