Below is my current setup followed by the end goal I am trying to achieve. Any advice is greatly appreciated.
Current Setup:
I have two CAT5e lines ran from every room in the house to a central location in the basement. At this location I have a ubee DDM3513 cable modem (provided by my cable company). This modem is connected to a Netgear wireless router (WNDR3700v3). The first port on this wireless router is connected to a TP Link Gigabit Switch (TL-SG1024D), and this switch needs to remain in this location.
Current Connections:
- Basement: It's unfinished, so we don't have any wired or wireless connections currently in the basement
- First Floor: Wired- Satellite Receiver, Apple TV, LaserJet Printer (does not have wireless capability)
- First Floor: Wireless- PS3 (This would be hardwired, but the receiver and Apple TV use the 2 ports for the living room and this PS3 isn't used for streaming, just disc play so I'm not too concerned)
- Second Floor: Wired- (2) Satellite receivers
- Second Floor: Wireless- Apple TV, PS3 for gaming (I have the ports available to hardware these, just need to stop being lazy and terminate the connections in the basement and add to switch)
- General Wireless: We have 3 laptops, 3 phones, and 2 tablets that use wireless. We really don't use any of these to stream on our network.
One of the obvious issues is that the wireless connectivity that I have with our wireless devices is not ideal due to the location of the router. We use our wireless devices on the 1st floor 70% of the time and on the second floor 30% of the time.
Additionally, we recently bought a Mac Air that supports 802.11ac. I purchased the 2TB Apple 'Time Capsule' in order to wirelessly back up the Mac Air through Time Machine, provide additional wireless storage for photo/video files (due to the small amount of storage on the Mac Air), and to take advantage of the Air's 802.11ac wi-fi support.
Desired Result:
- Connect Time Capsule to network in order for laptops and mobile devices to wireless access and/or backup (understanding that some cannot do this).
- Change primary wireless router to Time Capsule to take advantage of upgraded wi-fi support on Mac Air (primary family computer)
- Determine correct location for modem & wireless routers, and how they all need to be connected together to create an optimal network.
- Decide to remove or implement current router into new set up.
Other Questions:
- Should all hardwired devices run through switch, or should some that gaming or streaming are used be ran directly through router?
- Should any device capable of connecting to a 5Ghz do so, or should this frequency be reserved for certain applications (streaming, gaming, etc).
- What's the 'best' way to set up guest network? Is there a certain band that I should use, specific router of these two, etc. Or is recommended at all? I give out my wifi pass to all of my guests anyways, but it gets repetitive and I don't want them chewing up my streaming bandwidth ( I had 10 phones connected to my network over the holidays which made it a little difficult to SKYPE).
Thanks in advance for your advice, and I apologize for the length of the question. I just wanted to make sure that I provided enough details, and don't hesitate to ask if you need any further information.
Thanks
Dave
Current Setup:
Desired Result:
Other Questions:
Thanks
Dave
