Need part suggestions for PC build
What are your other current parts CPU/MB/GPU/PSU/Fans/HDD/SSD/etc.? Are you using the PC for gaming and/or multitasking/editing/workstation? What is your preferred case theme/motif?
Edit: As you have edited your post to show your parts, here's a suggested case/CPU cooler/RAM as you requested:
CPU Cooler: CRYORIG - H5 Ultimate 76.0 CFM CPU Cooler ($63.59 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory ($119.99 @ Newegg)
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case ($79.99 @ Newegg)
Total: $263.57
Prices include shipping, taxes, and discounts when available...
Total: $263.57
Generated by PCPartPicker 2017-06-24 09:18 EDT-0400
I will use the PC for gaming, a little bit of editing. I'd prefer black theme. Also what do you think about current parts? Should I change anything? Sorry forgot to post the partpicker at first.
If you are building now. Mining has wrecked mid range GPU prices. Buy the GTX 1080 as it hasn't been affected much and 1070 prices are nearly identical.
The WD Black NVMe SSD is a couple times faster than the 850 Evo for about the same price. It is a much better deal.
If you want a powerful mid priced cooler look at the Scythe Mugen 5. It does better under overclocked loads than a more expensive Noctua NH-D15s. It is their replacement for the Mugen Max. Which beat out the Be Quiet! Dark Rock Pro 3 and Noctua NH-D14. It is also quieter than the Noctua NH-D15s.
http://www.modders-inc.com/scythe-mugen-5-cpu-cooler-review/4/
Unless you want SLI later. You don't an 850w PSU.
CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor ($326.49 @ OutletPC)
CPU Cooler: Scythe - Mugen 5 51.2 CFM CPU Cooler ($45.88 @ OutletPC)
Motherboard: Asus - STRIX Z270-E GAMING ATX LGA1151 Motherboard ($199.00 @ B&H)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory ($126.99 @ Amazon)
Storage: Western Digital - Black PCIe 256GB M.2-2280 Solid State Drive ($109.99 @ Amazon)
Video Card: MSI - GeForce GTX 1080 8GB DUKE OC Video Card ($504.98 @ Newegg)
Case: Corsair - Crystal 460X RGB ATX Mid Tower Case ($139.99 @ B&H)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($88.99 @ SuperBiiz)
Total: $1542.31
Generated by PCPartPicker 2017-06-24 09:25 EDT-0400
My previous edited post (after your edited pcpartpicker link) was a gray+black theme. Here's another option, this time with a significantly black theme:
CPU Cooler: be quiet! - Dark Rock 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler ($64.88 @ OutletPC)
Case: NZXT - S340 (Black) ATX Mid Tower Case ($69.99 @ B&H)
Total: $254.86
Generated by PCPartPicker 2017-06-24 09:24 EDT-0400
The H5 Ultimate will block the first RAM slot, but using just 2 x 8GB (16GB) RAM at the 2nd and 4th slot is enough (recommended to not fill up all slots to minimize stress on memory controller).
Okay, thanks, as for the PSU, I will probably be using it after this PC goes out of date, so thats why I chose the higher wattage. My original pick was going to be the 750w but since the price is pretty similar I just went with the higher one.
As for the other parts of your listed build, a good-quality 550W PSU is more than enough (even with OC). I'd recommend you get the EVGA SuperNova G2 550 or G3 550 or the Corsair RM550x.
The GTX 1070 is ideal for AAA gaming on max settings on a 1080p/~75 to ~120 Hz monitor *or* a 1440p/~60Hz monitor. Consider a GTX 1080 if you are looking at 1080p/~144Hz or 1440p/~120Hz. Both GPUs on your listed setup can be powered by the 550W PSUs suggested above.
