Need PC advisor for my PC system
naz rain
Hey guys,i want to build a budget gaming pc for DOTA 2.So i need an advice weither my specification is goo enough to support it or not?
Processor :INTEL CORE I5 4440 3.1GHZ SOCKET 1150 PROCESSOR
Motherboard :GIGABYTE GA-H97N-WIFI LGA 1150 Intel H97
Graphic card :ASUS Nvidia GeFroce GTX750 1GB(GTX750-PHOC-1GD5)
RAM :Corsair Ram Desktop DDR3 VENGEANCE 2X 8GB
casing :BitFenix Casing Mini-ITX Prodigy WHITE
powersupply :COOLER MASTER ELITE V2 500W POWER SUPPLY
Storage :SEAGATE SV35 1TB 7200RPM
for second question i want to ask,weither i can cut the cost to build this pc but at the same can maintain a good performance for my pc.
if any suggestion pc specification for dota 2 budget gaming pc can list out it ? thankyou
p/s:this is my first time thread sorry for my english.
Example cheap Bulid that can handle dota 2 and Witcher 3 *( bulid can be latter OC need good CPU cooler and rams need tweaking to 2133Mhz)
From what county you are ?
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor ($69.99 @ NCIX US)
Motherboard: ASRock FM2A88M PRO3+ Micro ATX FM2+ Motherboard ($48.98 @ Newegg)
Memory: A-Data XPG V2 8GB (2 x 4GB) DDR3-1866 Memory ($47.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.99 @ Amazon)
Video Card: Sapphire Radeon R7 260X 2GB Video Card ($93.98 @ Newegg)
Case: Raidmax ATX-809B (Black) ATX...
psu need to change oh...ok2
whats the differrence between amd and intel?most people say intel > amd for some reason
any suggestion to change the graphic card to cheaper one? instead of gtx750?
and if i use without graphic card and using integrated intel graphic card still can play dota 2 with good fps?
Case: Raidmax ATX-809B (Black) ATX Mid Tower Case ($19.99 @ Newegg)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply ($19.99 @ Newegg)
Total: $350.91
Generated by PCPartPicker 2015-06-10 03:53 EDT-0400
Amd is cheaper although a bit behind intel. Think of it like this, you could get an amd chip at almost half the price of an intel chip by sacrificing a little in terms of performance. If you don't mind spending, go for the intel.
anyway, i found these somewhere:
AMD Radeon HD 7750 1GB DDR5
nVidia GeForce 9600GT 512MB DDR3
nVidia Geforce 8400GS 512MB DDR2
Intel HD 2500
These are just enough to run the game. i suggest you look for anything more powerful. Maybe the hd 6450 or the gt 520
