Need Pc Help - psu for case
For systems with two GeForce GTX 760 cards, NVIDIA specifies a minimum of 700 Watt or greater system power supply that has a maximum combined +12 Volt continuous current rating of 50 Amps or greater and that has at least four 6-pin PCI Express supplementary power connectors.
That's only for the cards, of course - you need to factor in the other components as well, and leave some headroom for longevity.
You also need a large case with much airflow.
Here is the PSU I would recommend (it has enough headroom and 10-year warranty):
http://pcpartpicker.com/product/29xfrH/evga-power-supply-110b20850v1
Yes it will fit in the case, however that power supply is junk, and definitely not nearly worth that price. Also you can get a better case to.
This is a much better power supply.
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($74.99 @ Newegg Canada)
Total: $74.99
Generated by PCPartPicker 2016-09-29 04:23 EDT-0400
I would recommend spending a bit more on a much better case with a Usb 3.0 port and 5 pre installed fans+dust filters.
Case: Deepcool KENDOMEN Black ATX Mid Tower Case ($54.99 @ Newegg Canada)
Total: $54.99
Generated by PCPartPicker 2016-09-29 04:24 EDT-0400
I already have the case so just need the psu and ram
Intel DX58SO motherboard
I7 950
Zotac GeForce GTX 760 2GB
MSI GeForce GTX 760 Gaming OC
The cx750 isn't great quality & is commonly known for being a 650w PSU in a 750w casing.
With you saying sli I'd say with almost certainty that a good quality 650w would do the job & would be a better choice than the corsair
As already asked , but what are the full system specs you're building??
I7 950
