Need PCI (legacy) to USB 3.0 add-in card with 20-pin header
clutchc
Ambassador
I need a USB3.0 add-in card for a (legacy) PCI slot that has a 20-pin internal header. I can find PCI Express cards up the %#$, but not PCI. Or, at least not ones with the 20-pin header. Am I wasting my time? They don't exist for some reason?
PCI has a 133MB/s transfer limit which is far lower than the actual transferrate of usb 3.0 so you won't be finding those cards. Any reason you would need 3.0 in a legact system?
I working with a board that does indeed have a PCIe x1 slot, but it sits right next to the gfx card. The add-in card would cover the gfx card's front fan.
That, and I would like to have one on hand for future use with older boards.
yea the old PCI bus is in MB/sec while the PCI-E bus is GB/sec
