Need Perfect Advice: Upgrading and purhasing my system CPU [AMD vs Nvidia vs Intel] [Graphic card, processor,Motherboard]
Arham_saif
Commendable
Oct 6, 2016
24
I am looking to buy a gaming computer and i am damn confused what to buy.my final buget is $1030.
here is the thing which confused me:
Graphic card: Nvidia GTX1060 or AMD R9 fury tri-X.
Processor with MoBo : (AMD fx8350,8320 with Gigabyte 990fx gaming MoBo) vs (Intel i5 6400 with gigabyte z170 gaming 3 MoBo)
Don't get an AMD processor. I'd much rather get an i5 6500 and a b150 motherboard since it's a locked processor. Also, the 1060 will use a lot less power; you could even squeeze a 1070 into that build if you wanted to.
Dronzer Dragneel
Respectable
May 13, 2016
402
89
Don't buy Z170 mobo..go with H170 or B150..and for the memory go with 2133 speed..that would be enough and maximum supported..if u go with 2400 your system gonna downgrade it to 2133 so its no use..and get 600W 80+ gold certified PSU (better be safe)
Arham_saif
Commendable
Oct 6, 2016
24
Thanks bro.. but what about R9 nitro? or Z170 is not good for gaming?
Arham_saif
Commendable
Oct 6, 2016
24
Thanks bro and what about Processor?
Dronzer Dragneel
Respectable
May 13, 2016
402
89
Processor is good for gaming..but if you want to play hard I'll recommend the following:
Processor Intel i5 6600 (as it is not unlocked (K) processor no need for after market cooler)
H110/H170 Motherboard
2 x 4gb DDR4 Memory (Speed 2133)
128gb SSD for OS
1TB HDD
GTX 1070 (Cheapest available)
550-600W 80+ gold PSU (Seasonic, EVGA, Corsair)
Case-it's your Choice and Preference.
And forget about AMD.. ;)
theyeti87
1,762
223
MERGED QUESTION
Question from Arham_saif : "Advice me what should i buy i5 or Fx8350"
Go the Intel route. You'll get more years out of it. The FX8350 and its platform are on the precipice of being replaced entirely.
theyeti87
1,762
223
MERGED QUESTION
Question from Arham_saif : "Advice me Motherboard for Gaming"
Z170 = enthusiast
H170 = H for Home
B150 = B for Business
Absolutely go for the i5 and not the FX. If you want a locked CPU (non overclocking), go for the 6500 instead. The extra few hundred Mhz is noticable.
Of the 1060's, the 6GB model is the way to go, not the 3GB one.
Similar threads
