Need a good power supply unit and fan (if any is needed) for the build below.
OVERCLOCKING: No
SLI OR CROSSFIRE: No
FAN+PSU BUDGET: ~$400
ADDITIONAL COMMENTS: I'd like it to be quiet and not eat up a hellacious amount of power. Don't want to have to add more than 2-3 fans. Not willing to mess with water cooling. Probably won't upgrade most parts for 4-5 years; my current computer lasted 8 years and I'd like another one that will last me for about as long. May upgrade CPU and graphics card a bit in a few years and/or add another HD.
The Build:
CPU: Intel Core i7-930
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115225
Mobo: ASUS P6X58D Premium
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131614
Memory: G.SKILL PI Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231335
Case: COOLER MASTER HAF 922
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
Hard Drive: SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
DVD Reader: LITE-ON Black 18X DVD-ROM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106276
DVD Burner: LITE-ON Black 24X DVD+R...
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335
Graphics Card: XFX HD-577X-ZNFC Radeon HD 5770 1GB 128-bit
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150462
OVERCLOCKING: No
The Build:
