Need psu upgrade help
Sep 2, 2018
Buying an hp 595-P0084 that only has a 180w psu. Moving my video card from my old machine. Graphics card is 1050 ti mini that runs off of the motherboard(no separate cable to psu) but still recommends a min 300w psu. If I’m going to upgrade it anyway I’d like to get min 500w but up to 750w if possible in case I upgrade later. What psu would fit this machine?
Non standard board & connections means a standard atx is not going to work.
Honestly if you plan on future upgrades I would steer clear of that HP prebuild completely.
Thanks to you both. I was nervous about the HP to begin with, but it was an affordable option if I could add my existing GPU and SSD. I think I’ll just look for a better albeit more expensive choice to save myself the future frustration.
