Hello all,
I plan on replacing several fans on my antec 902, including the exhaust fan, with the following Xiggy (mostly for aesthetic reasons in going with an orange-themed rig)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233015&cm_re=xigmatek-_-35-233-015-_-Product
Also, I want to replace my hyper 212+'s current push/pull fans (stock fan and old temporary fan that was in my old rig) with these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185060&cm_re=slipstream-_-35-185-060-_-Product
I'm not too keen with airflow theory, but with a setup like that, would air coming from the push/pull get "clogged" on the way out of the exhaust xiggy, since the exhaust is only running at 61cfm/1500 rpm compared to the slipstream's 1900 rpm. Also, I have the 200mm big boy exhausting up top. Would that essentially help in "unclogging" any stuck air?
I'm a bit confused. Thanks in advance for the advice :]
(also, sorry for the double post. I realized I posted this on the wrong section this morning)
