I have the same thing and I built a custom liquid cooling setup. If you are cooling just the one card then a 240 radiator with a good quality pump will do. If you are looking for a complete set allready to go then Koolance makes some good units.
http://www.koolance.com/water-cooling/default.php?cPath=28_41
Problem is the a lot of the other kits from other companies come with a cpu cooler block and or a gpu cooler block. That is why I went and built my own setup. If you go with the Koolance one then the Exos unit has a built in pump , radiator , fans and resivoir , all you need is tubing and fittings which you can get everything you need an the Koolance site. One of my first cooling setups was a koolance Exos.
