need recommendation for replacement for geforce g100...
wider is going to be an issue for fitting back in the case
1. It's just his old PC. Mostly surf the web...doesn't need much.
2. I will see if I can find a link for his whole PC...looks like a 220w PSU
http://reviews.cnet.com/desktops/acer-aspire-x1700-u3700a/4507-3118_7-33508017.html
3. Would like to keep it under $25 if possible as I'm not 100% sure this is the issue.
No longer the main issue...somehow between testing it a few weeks ago and today the plastic piece to the power connection on the hard drive broke off and is stuck in a power plug. I am just going to trash it I guess.
Thanks for the help anyway!
I broke a sata connection on a HDD once, they seem to be thinner than most would believe, if it is power though you may have a drive with both molex (4-pin) and sata power inputs, so it may still be usable best of luck in whatever you end up doing :)
