Need recommendation to Finish my rig.
G
Guest
Guest
Processor: Intel Core i5 3570K 3.4GHz Ivy Bridge
Motherboard: Asrock Z77 Extreme 4
Memory: Corsair Vengeance 4GB 1600MHz DDR3 <-- can i up this to 8Gb? any negative effects?
CASE: COOLER MASTER ELITE 431
USE:
Extreme gaming,OC,server,rendering,dual monitor.
Is this right or do i have any miss match or incompatibilities?
Any recommendations?
Hope someone helps me.
ahh but i'll be rendering for AutoCad and 3D Max in the future.
So i think i'll need 8Gb but please correct me if im wrong.
I'll try to buy or order from where i am.
Has beefier cooling, has support for mini pci(located between PCI-E slots for crossfiring) handy for adding a wifi card, has a Display port handy for connectivity, onboard 1394 port and :lol: floppy connector :lol:
just looks better IMO + Tom's approved board.
thank you for that mate!
no mate,
mobo:
the asrock z77 extreme6
case:
fractal core 3000, Define R4 midi
corsair carbide ,300R ,400R ,500R
ram:
mushkin ridgeback blackline 8GB kit 1.5V
corsair dominator platinum
or corsair Venegence 8GB kit in black.
links:
http://www.techpowerup.com/reviews/Fractal_Design/Core_3000/
oh you can watercool in a fractal. wait dya mean watercooling like the Corsair Hydro series coolers? don't bother wasting that money. Might want to look at my sigs to see my ongoing watercooling projects and the watercooling sticky to educate yourself about the real thing.
i don't know what water cooling i'll buy since i have limited budget and i'm concentrating on MoBo and Cpu atm. those two eats up my budget haha.
Since i want my build to last for years and upgrade them if games req start being a b1tch with crappy story>,<
ok i'll take the factual if it can accommodate water cooling.
I have CD and DVD writer.
I plan to use 2 HDD.
Can that case accommodate them?
