Need replacement fan for P4
Brad_Barker
54
My stock P4 fan is starting to make really funny noises and I need a replacement fan for it. I have been looking at all the fan and heat sink combinations, and I don't know what to buy. I just need something simple to replace it, so my system doesn't go into a melt down. Any help/ideas is greatly appreciated.
<font color=orange>OW</font color=orange> <font color=orange>OR</font color=orange> <font color=green>GW</font color=green> <font color=blue>BL</font color=blue> <font color=blue>BW</font color=blue> <font color=green>GR</font color=green> [brown]BW[/brown] wait... There is no brown markup!! :frown:
I dont know if you can buy just a replacement fan for your Stock HSF.You might want to give intel a call and see if they will send you one.But somethi8ng like this from arctic cooling should do the job <A HREF="http://www.frozencpu.com/cgi-bin/frozencpu/cpu-arc-04.html" target="_new">http://www.frozencpu.com/cgi-bin/frozencpu/cpu-arc-04.html</A> or if you want to spend a alot of money you could get this <A HREF="http://www.frozencpu.com/cgi-bin/frozencpu/cpu-tri-07.html" target="_new">http://www.frozencpu.com/cgi-bin/frozencpu/cpu-tri-07.html</A>
40k in aquamark 3
<A HREF="http://arc.aquamark3.com/arc/arc_view.php?run=682299587
" target="_new">http://arc.aquamark3.com/arc/arc_view.php?run=682299587
</A>
P4b2.4@2.8||1024mb DDR@392mhz||9800pro@414/732||Viewsonic UltraBrite 19"||Panisonic DVD-RW
