Need Replacement Fans for Thermaltake Water 2.0 Extreme CPU cooler (the 2 fan one)
cn7
5
Two of the blades broke on one of the radiator fans in my unit and I need to replace it.. Just not sure what fan to replace it with.
I'm also considering just getting 2 new fans, probably quieter ones.
If anyone knows where I can get the original fans or has a link to share for some quieter, equivalent or better fans, I'd appreciate it.
Thanks.
Here are the specs for the fans from the Thermaltake website:
*Sorry, I don't have the ability to open up the system and look at the back of the fans ATM, so I can't say what brand or model number they are. Kind of running around with my head cut off!
Dimension : 120 x120 x 25mm
Speed : 1200~2000RPM
Noise Level : 27.36dBA(Max)
Rated Voltage : 12V
Rated Curre : 0.5A
Max. Air Flow : 81.32CFM
Connector : 4 Pin
what about
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608026
max air flow - 93.4
noise level - 22.4
