need review and comment for any little change
Sudip Das
15
i5 4690
gigabite H97 D3h mobo
(8X2) 16 gb ddr 2 corsair vengeance ram
samsung ssd
CORSAIR CX600 power supply
ZOTAC GTX 730 2G DDR5 graphic card
1. 600 wt are good for my rig, or i have to increase the power. please suggest. :)
2. Excessive power like 750 wt or 1000wt harmfull for my rig ?
Antec. XFX, Seasonic, EVGA B2 or G2 are what I would be looking at, and nothing else. Even with a GPU upgrade and overclocking, a 650W PSU is plenty (if made with high-performance parts)
600W is plenty. I would prefer a Seasonic or Antec PSU for a high-performance computer like yours. You have a 'truck' PSU in a 'racing car'. Too big will not hurt your system, but PSU's run less well at low load. I would be happy to use a 750W PSU with that, but I would not want to go much higher; your system could run on 400W.
As you say my system can run with 400 wt PSU, but for good long run i have to go with 750wt .. I have little budget problem but i need a good enough PSU for my computer. Please suggest . Thank You
I am a Graphic designer. I am mostly use Photoshop, illustrator for full size work. As a example 20 ft X 50 ft Hording with 200 dpi resolution, Pattern developing in 8 ft X 5 ft with 300 dpi resolution. Some time I am use MAYA and 3D max for my design.
Some time for relaxing I am playing game like Call of duty, Tom Clancy's Rainbow Six, Battlefield, project IGI, NFS most Wanted etc.
