Hello!
I am going to buy my first PC and i am curious about best choises i can make.
Main requirements for PC are:
For now i have chosen:
Please, let me know, if i did some mistakes in my PC build or there are better components i can buy.
Thank you for attension!
1. Gaming at 60 FPS in all games.
2. Work with multiple resource-intensive applications simultaniusly (like IDEs).
3. Good audio quality.
1. CPU: Intel i7-6700 non-k
I am not sure i need overclocking. I guess for most of my tasks this CPU would be great.
2. Mobo: Asus H170 Pro Gaming
This mobo is almost as expensive as Z170. Maybe i have to look at Z170 instead?
3. GPU: Asus PCI-Ex GeForce GTX 1060 ROG Strix 6GB
It looks for me like an optimal choise for gaming at FullHD.
4. Power supply: Aerocool KCAS-500 500W (4713105953275)
Is it enought for my build? Power supply calculator said that "Recommended PSU Wattage: 366 W"
5. SSD: Samsung 850 Evo-Series 250GB 2.5" SATA III TLC (MZ-75E250B)
I want to install OS and programs here.
6. RAM: Kingston DDR4-2133 4096MB x 2 HyperX Fury Black
Is 8 GB enought for my requirements? Or shoud i pick 16 Gb instead? Also, mobo specs said that it supports only 2133 MHz. So there is no need in RAM with higher frequecy, isn't it?
7. HDD: Western Digital Blue 1TB 7200rpm 64MB WD10EZEX 3.5 SATA III
For storing files like music, movies, documents, huge games etc.
8. CPU Cooler: DeepCool Gamma Archer Pro
9. Case: DeepCool Kendomen TI
Because it has built-in coolers. Not sure about it.
10. Monitor: 23.8" Dell P2417H (210-AJEX)
I want a good monitor, because i spend a lot of time with PC.
