Hey ladies and gents. I am pretty much a noob so please be patient.
Here is the deal. I am having problems with a Linksys WRT54G router. I cannot get it to work at all when I plug the ethernet cord into the WAN port but it does work when I plug the ethernet into one of the 4 LAN ports....but then it constantly drops the computers in the house and then I have to power cycle the router or reset it for the computers to be able to access the internet.
I should elaborate on my network configuration since this most likely is causing the problem. This router is in a guest home several hundred yards away from the home where the internet comes through a satellite modem so I have bridged the internet over to the guest house wirelessly. Order of setup is Satellite Modem>>>Linsys WRT54G router>>>Engenius Access point>>>Engenius bridge>> another Linksys WRT54G router.
Let me mention a couple of more things. When I hook up to the bridge via ethernet cable the internet is always coming in strong, I am just having problems with the router. Also I have given all the hardware pieces in the network seperate IP addresses. The router has no security setup on it and is running on all the default settings except for the given IP address.
What should I do to fix the problem? Thx in advance
I am pretty clueless here
