The problem:
Whenever I attempt to play a game, of any kind, within a few minutes, my monitor suddenly goes blank, and the system locks up tighter than a drum. The only way to shut down the computer is to unplug the power cord from the wall, including the UPS. Restarting is difficult ... and may take up to an hour before the system will finally boot up. The computer WILL restart ... but only up to a point. It acts like I do not have a video card installed ... no beep codes, no display of any kind. Re-attaching the power cord to the computer causes a spontaneous reboot, but it may or may not actually load. As you can imagine .. this is becoming frustrating, because this only happens when attempting to play a game ... no other applications have any problems. And if you are thinking it ... no, with no display, no DOS, and no access to the BIOS. And it's not the monitor ... I've got a spare.
The Specs:
Win98 SE
1000MHz Athlon Thunderbird (Socket A)
MicroStar K7T Pro, with the KT133 VIA chipset (MS-6330)
256Mb Virtual Channel Memory (Micron PC-133 SDRAM)
18GB Ultra160 SCSI IBM hard drive
Adaptec 29160N PCI SCSI controller (Ver 2.57 BIOS)
Adaptec AIC-7850 PCI SCSI controller (for my Microtek SCSI-2 scanner)
Plextor CD-R PX-W124TS
Pioneer DVD-ROM DVD-115
Creative SoundBlaster Live! X Gamer
REALmagic Hollywood Plus MPEG decoder card
D-Link DFE-530TX+PCI Adapter NIC card (for the cable modem)
Iiyama Vision Master Pro510 22inch monitor @1024x768, with a "normal" refresh rate of 100Hz. (This includes a "custom" Direct Draw setting of 100Hz.)
300watt Antec power supply
Seven 80mm cooling fans. Three intake fans, and one directly on the video card. Three exhaust fans, including the one in the power supply, and one slot fan directly underneath the AGP port. Decent fan and heatsink on the processor ... although the fan on the video card is stock. (My bad.)
Direct X 8.0a Retail
Latest drivers for the SB Live card
AWARD BIOS, Ver 1.6 , Flash date 9-20-99
Things that led up to the current problem(s):
Yes, for a while I had the computer overclocked. But I was very careful about it. I studied all the material I could get my hands on, prior to overclocking. The processor was never overclocked higher than 1030MHz. The video card was overclocked to 393MHz on the memory, but due to artifacting during testing, I never raised the core from the default of 200MHz. The video card was not overclocked all the time ... only when I played games or watched DVD's.
Initially, I had tons of problems with this video card, because not all nVidia drivers will work with the VIA KT133 chipset. This is not something I have been able to find much information on, since most benchmarking tests and reviews I had seen prior to assembling the computer were done with Intel mobo's and processors. It didn't take me long to install the Detonator 6.31 drivers and the latest VIA 4-in-1 drivers, which at the time were the 4.24's. Afterwards, the computer ran fine for six months, with only the occasional stutter in a game like MechWarrior 3, or Pirate's Moon.
I did find it necessary to add the Hollywood MPEG card in order to play DVD's without the computer crashing ... and even this did not work well unless I overclocked the video card memory. (I use Power DVD 3.0, by-the-way. It's got it's own share of bugs, but that's another story ... and another forum.)
A few weeks ago, I installed MechWarror 4: Vengeance. The game ran fine at first, and then the problems started happening. The monitor started going blank, suddenly ... the system locked up ... and it can take quite a while before the system will reboot.
I checked repeatedly... temperatures inside the can were normal. I really don't think this is a heat-related issue.
I've done memory diagnostics, motherboard diagnostics, checked voltages ... you name it, I've checked it. Unless I play a game, the system functions normally.
Intending to try and beat the problem, I installed the latest VIA 4.28a drivers. I was surprised to find that the last modification date of these drivers is 12-21-99. Suspecting that I might have gotten shafted somehow, I went to the VIA site and downloaded and installed 4.25a. The date on these drivers is much newer than 4.28a. 8-10-2000 for the CPU to AGP controller driver, and 4-5-2000 for the CPU to PCI Bridge driver. I bet you think that's odd. Join the crowd.
After all of this, I attempted to play my newest game; Giants: Citizen Kabuto. Fellows, I never got pass the screen where you create a name for your character. Yep... you guessed it. WHAM ... no display. Thirty second of game play. Not exactly what I had in mind.
This really pissed me off. Something fierce.
I took the computer apart. I cleaned everything. I blew out all the nooks and crannies. I took out the CMOS battery, and completely set the BIOS back up, everything from the memory speed, to arguing with Windows over the SB Live 16-bit emulation and why I believed that it should share IRQ 9 with the Epson printer port, despite valid, prissy, typical Windows complaints. I reinstalled the OS. I checked the Registry for corruption. I did a lot of cussing, too ... although that's to be expected, I guess.
After three hours ... the computer finally rebooted. What really pisses me off is that I don't know why. Why it locked up AND why it decided to reboot.
So ... after all of this complaining <GRIN> ... here's what I'd like to know:
What caused the problem? Anyone have an educated guess?
AND ... what IS really the latest VIA 4-in-1 driver set?
AND ... (yes, MORE!) Will the latest Detonator 6.50 drivers on the nVidia site work with the VIA KT133 chipset?
I've noticed some of you mentioning Det 7.X drivers. Where do you get these ... and will any of these work with this chipset? Drivers meant for Intel mobo's do horrible things to your display ... and I'd hate to fight this machine, with the way it's been acting, in order to get the old Det 6.31's back in again. I've done it before, and it's tough when you can't see the desktop, even in Safe Mode. Catch my drift? LOL!
Finally ... well, do you think overclocking the memory on the video card damaged the card? If I had a spare video card, I'd already know ... but that's not an option. I don't know many people around my town who have a clue how to use a computer, much less would let me dig around in their new DELL and borrow their video card. IF they knew what I was talking about in the first place. This place is a damned retirement village, and email is still a new thing to these folks. <SIGH> Such is life. It's a good thing I like older women.
Note: AGP 4X is enabled in the BIOS, and the memory is set on TURBO. The VIA AGP controller driver was installed at the TURBO setting. The AGP aperture setting in the BIOS is 128.
If you guys don't have any answers for this ... then I am out of luck. Money is tight, right now, and I can't afford to run out and buy a new mobo for a while, despite VIA's lackluster memory bandwidth reputation. I want to get this card, chipset, and the latest games to run. Together, all at once. Without dying in less than a minute. That's the whole point of having a decent machine if you are a gamer ... and so far, all I've been doing is technical support for myself. That, frankly, just sucks.
HELP!!!
All replies, no matter how far-fetched, will be greatly appreciated. Especially if you've read this entire message! If so, you're either a brave man, really bored, or very interested in my problem, and chock-full of real-world information I can use to my advantage. Hint, HINT!!
I'll shut up now and let wiser heads prevail.
Toejam31 (Somewhere in .VXD Hell, I think.)
The Specs:
Win98 SE
HELP!!!
