Hi I am in the UK can anyone recommend the right components to get a fan running with out a Motherboard.
I am looking to make a Jerky/Biltong box so I need a good flow of air from a fan(s), I do not want to start playing around with DIY wiring so I want to use PC components.
If use I PC power supply I am thinking that unless the mainboard tells the PSU unit that its on the fans wont run so am looking for recommendations for the right components to simply run a fan as soon as the power supply is turned on?
Thank you.
Thank you.
