Question Need some adivice with case raditator placements, for optimal cooling
Azidran
6
Hello,
I am currently building a new computer but i am honestly not sure how to place the radiators in the case for optimal cooling.
The case i am building in is a Lian Li o11 dynamic XL.
The problem i am running into with placement is that i am running a
Corsair Hydro Series H150i PRO RGB combined with a Gigabyte Aorus RTX 2080 Super Waterforce so i am here looking for adivece how to place the radiators, usually it has been easy when just CPUs radiator but now with two i am not to sure on how to place them in case seeing only one can go on the top.
I dont think it will make much of a performance difference because that case is so well ventilated. I would take the placement with the best optical fit. Maybe cpu to the top and gpu to the side? That should have the cleanest look dont you think?
