Hi, basically I am looking to purchase a high end custom build from a site called scan.co.uk.
Here are the main specs of what I am buying:
Asus P8Z68-V, Intel Z68 Chipset Motherboard
Intel Core i7 2600K, 3.4Ghz, Quad Core
2nd Generation Intel® Core™ Sandy Bridge CPU professionally overclocked by our 3XS engineers to 4.7Ghz
8Gb (2x4Gb) Corsair Vengeance LP, DDR3, 1600Mhz
4Gb XFX HD 6990
650W XFX Core Edition PSU
Be Quiet! Dark Rock Advanced BK014 CPU Cooler
120mm Akasa Apache Black Ultra Silent Fan
My concerns primarily are with noise, heat and power usage, so here are a couple of questions.
Will this build require a better PSU?
Should I look into water cooling or will the the fans listed be enough?
2x 6970s would give me more graphical power, but would it use more power, create more heat/noise compared to a single 6990? Whats the best middle ground.
Any help and further advice on my build would be much appreciated, thank you.
4Gb XFX HD 6990
