Hi guys,
The idea of a home server or NAS is banging on my head since last month, so I did some research and I need a bit of advice in the parts and in a couple of questions.
First the questions:
-I have 300 Mbps with Vodafone on my optic fiber, but all my switches, my PC and cables are all capable of doing 1 Gbps, so does that mean that if I'm only using my Network (Not Internet) to access to my NAS and stream 4K content from there, will the limit of the speeds be 300 Mbps or 1 Gbps? (All my setup and devices are 1 Gbps capable but Vodafone only offers 300 Mbps MAX in my country)
-I'm stuck in the software to use...FreeNAS seems suitable, but should I use Linux or Windows Server Instead? I would like a software that can block devices that are trying to access my NAS, for example I would like my PC and my Oppo UDP-203 to access the NAS but I wouldn't like a member of my family just getting their laptop and accessing my NAS server in case they think it's just an additional HDD and they end up deleting stuff or changing stuff I would like some O.S that can at leas encript the server or just ask some password everytime you access to it from a different device (for the first time only).
With that being said, here is part of my build:
-Intel Pentium G4560 perfect CPU for this, 2C/4T at 3,5 GHz with support for ECC RAM and HW Decoding H.265 4K 10 bit HDR BT.2020 files. I found one on my local store for just 54€ also supports up to 64 GB RAM.
-Case: Silverstone DS380B I fell in love with that case here is about 170€ requieres SFX PSU and Mini ATX motherboard I think (PSU I'm sure it's SFX)
-Motherboard...Well I'm stuck with that one I was expecting some advice in this one, the only requirement I have for this is an HDMI 2.0a port, USB 3.0 ports...and 1 Gbps port...if it can have more SATA ports, then better, but if the cost is going to be more than 150€ then it's not worth it. If it's a standard MiniATX motherboard then the requirements will be HDMI 2.0a port + USB 3.0 port + Ethernet 1Gbps port and at least 3 PCI Express as I may upgrade to a 10 Gbps card + RAID controller and I may add in the future a GTX 1050.
If you can list me the cheapest mobo with ECC support for running ECC Registered it would be also nice, but not really my focus. Budget for mobo should be around 80€ maximum.
-RAM: Haven't decided yet but I'm not using ECC so I will start with a 16 GB stick DDR4 2133 MHz, As I would like to have the maximum amount of RAM possible to 64 GB in a future, I would like to have 4x 16GB sitcks (I will upgrade periodically when I upgrade my storage). The price here is aprox 85-110€ per stick.
-PSU: It need's to be an SFX so I thought of the Sharkoon SFX 450W 80 Plus Bronze I've seen very good reviews and I don't think my sistem would go further than 400W with like... 64 TB and 64 GB RAM fully loaded. This is 59€ to be exact.
-CPU Cooler: Noctua NH-L9L/i whatever, it has support for LGA 1151 and is small, price about 37€, will this feet into the case???
-I was also thinking in adding this:
https://www.amazon.es/dp/B00AZ9T3OU/ref=pd_sbs_147_3?_encoding=UTF8&psc=1&refRID=C8VJJXSRE16S4BMBSH0Z
My main use is going to be access files only. Files will be accessed from my Desktop PC, Laptop, and my Oppo UDP-203.
Type of files: Music and Movies
-Music will be DSD, FLAC, MP3,ALAC from 16 bit to 24 and from 44,1 KHz all the way up to 192 KHz
-Movies: from simple 720p, 1080p H.264 with AC3 tracks all the way up to 4K H.265 10 bit HDR BT.2020 with Atmos & DTS:X track, 4K files are up to 98 GB MAX so will this system work on that?
Are there any bottlenecks? Are the parts compatible with the case, cooler etc?
Thanks a lot, I will give a massive thank you to whoever answers as I'm struggling to figure out the whole thing.
