Need some advice on my current setup!
Andy211
Commendable
Mar 11, 2016
11
Hi there guys, not sure if this is the right section if it's not sorry in advance! I was just wondering if any of you could point me in the right direction in what needs upgraded on my setup to get the best out of it - as I don't want to be spending money on components that isn't necessarily needing upgraded etc.
Here's my build -
Operating System: Windows 7 Home Premium 64-bit SP1
CPU: AMD FX-6200 - Six Core Processor
RAM: 8.00GB Dual-Channel DDR3
Motherboard: ASUSTeK COMPUTER INC. SABERTOOTH 990FX
GPU: 4095MB NVIDIA GeForce GTX 960 (MSI)
Memory: 931GB Seagate ST1000DM003-9YN162 ATA Device (SATA)
Display: 22W_LCD_TV (1920x1080@30Hz)
Woops I knew I missed something my PSU is a Corsair TX650 I hope that's good enough, do you have any recommendations on what CPU to go for with my current set up? I've just recently upgraded the GPU to the 960 due to my old card giving up (Don't tell me I choose a bad card?:/)
Ah alright, I was thinking of going to Intel I5 but no clue on which one would be best and what else I need along with it (Motherboard etc).
When you say abit bigger how much are we talking? Haha, as I'd rather spend more for something if I knew it would be worth it in the long run if you get where I'm coming from
That's exactly where I'm coming from 😉 You could get a very basic Intel CPU and mobo, but it prob wouldn't keep you happy long, much the same as not real pleased with what you have now, about $300 would get a good i5 and mobo that would keep you happy a couple years or more (maybe 😉 )
Yea I'd rather get a better i5/mobo now instead of buying something that wouldn't do any good nor last long. Have you got any i5's in mind that would suit my build?
Also just wondering does my tv/monitor affect performance in anyway? It's quite old aswell 😛
Ah okay thanks for the quick response guys! What kind of motherboard should I be looking for?
Pne more thing do any of you know any place that's doing good deals on i5's/mobos? at the moment
Alrighty so do any of you know what cooler I should go for? (I've got one already not sure on what it's called) and would I need any new ram etc?
Ps if anyone can make a build on that part picker on what to get would be much appreciated!
