Need some advice on static and grounding
Tehcookiemonster
11
Ive worked with several pc's in the past but not enough to care about static.
Recently purchased components which are fairly expensive and dont want to take a risk.
Where would i plug my anti static wrist strap on my corsair 750d? I cant see any unpainted parts.
Are there other areas i can plug the strap to? I live in australia if thst makes any difference.
The best way is to connect the strap to a grounded metal.
Options:
- Most houses, no matter where you live, should have grounding connection on each power plug.
- Metal water pipe or water hand
- Metal room heater (the heater in Germany is good for this purpose, I dunno for Aussie)
Dashman9000
240
7
18,765
53
Connect your wrist strap to an un-painted metal piece on your case or inside the case, like a screw inside the case that holds attaches to one of your PCI cards or slots. If you want to get real serious buy a anti-static mat.
