Need some Advice
Chunkinator
23
Hello folks..
I'm needing some help deciding what Graphics card to get.
I'd strongly prefer nVidia.
Case: HAF X
Mobo: ASUS P8Z68-V PRO/Gen3
Display: One 1920x1080, One 1680x1050
I'm wondering what to get, I'd like to save some cash..
The eVGA GTX 580 looks great, but it's expensive, So I started looking at GTX 570's and I'm not sure which brand to go for...
I've also been looking into GTX 560ti's, 2 of them in SLI would be 15% cheaper than a single GTX 580...
So, Any help please ?
They're getting upgraded? Really? I didn't know that..
Well atm, 2x GTX 560 ti are a bit cheaper than a single GTX 580,
How much of a performance boost will I get with 2x GTX 560 ti's instead of a GTX 580 (At standard Clock Speeds)?
And will there be any problems with SLI in any games ? If so, What games ? I'd really like to know.
Well a GTX 570 is on par with a HD6970 by the looks of it, I'll be using a single 1920x1080 display for gaming...
What brands of those Cards would you recommend ? If I get either of those I'll probably SLI/Crossfire in the future...
2 X GTX 560ti's are faster and cheaper than the GTX 580, it also depends on the games being played.
SLI in games all comes down to the drivers , most games have updated SLI profiles for the games to run optimal.
560ti's will be upgraded to be on par with the gtx 570.
Wow, Could you give me link to a page with more detail?
Cause I think I might wait if that's the case...
