So the thing is that I want to water cool my PC that I'm going to build, but I'm having trouble understanding the fittings (English isn't my first language). Like what is a female end and a male end on a fitting. Do I need to buy a separate fitting to go in the waterblock then a 90° fitting if I want to make the bend imediatley or is there a fitting that has both in one? Is there consistency between all the components, like all waterblocks have male ends and all fittings female and all tubing goes into a male end or vice versa? If it helps I'm planing rigid tubing.
