Need some feedback/help with this system build I have selected
MaseWiN
36
After over a month of deliberation I think I have finally settled on a setup. Originally I thought I was going to go with an mats build and the aerosol ds cube but it is just taking too long to come out. I really liked the looked of the Air 540.
A few questions I have are:
1. Anyway to make this build cheaper?
2. Recommendations for a monitor preferably 27inch but 24 is also fine.
3. Is it worth spending a little extra on the vapor or should I drop down to a regular r9 280x
Also I would like to add crossfire down the road.
Any other feedback would be appreciated.
Thanks
http://ca.pcpartpicker.com/user/MaseWiN/saved/2JGx
Comments:-
you say you're planning to add another graphics card later, I think you'll need a bigger power supply, something more like 800-850W, others may want to comment on this as well
judging by the parts list this is a complete build, do you have or plan to get a mouse? there isn't one in the list
Comments:-
Yes I have a razor naga, and this is my first build in over a decade I was originally looking at 850s wasn't sure if that was too big. So I will change that thanks :)
