Question Need some help building a gaming pc.
Aug 14, 2019
9
EDIT: Not sure if this is the right place to post it, sorry if im wrong.
Hey, i want a new gaming pc but my knowledge about components is pretty bad.
I want a streaming and gaming pc.
I asked my friend, who knows a lot about it, to help me and he came up with these parts.
If u have any recommendations for some other parts, please tell me.
I already have a SSD and a HDD so I don't need them.
CPU- AMD Ryzen 7 3800X
CPU Cooler- Cooler Master, Hyper 212X
Graphics card- MSI RTX 2080 Super Ventus XS OC, 8GB
Motherboard- Gigabyte B450 Aorus Elite
RAM- Kingston DDR4 HX Fury, 16GB, 3200MHz
Power Supply- Fortron Hyper M 700W
Case- NZXT H510, ATX
Thank you.
Thank you.
Not a fan of 3800x, pretty much a 3700x with more wattage. If get a 3700x or 3900x based on budget.
B450 Board will need a bios update. MSI max boards work out of the box or get a x570.
Get DDR 3600mhz if you can afford it. Best performance for Ryzen.
Hyper 212x should be fine for a 3700x but depends on many factors such as ambient temp and case airflow.
That PSU looks bad, never heard of it. Look for a QUALITY Seasonic, Corsair or EVGA. Bitfenix has some good ones in Europe.
Aug 14, 2019
9
I found this
AMD Ryzen 7 3700X, but it comes with a cooler. Should i get Cooler Master, Hyper 212X and leave the cooler that come with the cpu or should i just use the cooler that comes with it?
Which MSI Max board do you recommend?
Is this RAM good? Memorija Kingston DDR4 HX Pred. RGB, 16GB(2x 8GB), 3600MHz .
Should i get a 550W or a 650W PSU?
Thanks.
I found this
Thanks.
I’d try the stock cooler and see how it works before spending extra money.
Tomahawk max would be the cheapest I’d go.
Ram looks good.
650 watts if you can afford it, 550 should be ok
Aug 14, 2019
9
Ram looks good.
Now that i checked, that's a little over my budget.
I there something i can downgrade?
(I was thinking the graphics card since it's pretty expensive)
