Need some help choosing a monitor (Both ASUS)
Awackypenguin
24
I've been looking at two monitors for a little bit now, and I'm a bit stuck.
One is the ASUS VH238H
http://us.ncix.com/products/?sku=61452&vpn=VH238H&manufacture=ASUS
And the other is the ASUS VS239H-P
http://us.ncix.com/products/?sku=74115&vpn=VS239H-P&manufacture=ASUS
The VH238H I believe is a 120hz TN monitor while the VS239H-P is a 60hz IPS monitor (Correct me if I am wrong).
I'm leaning towards the VS239H-P since it is an IPS, but I'm also leaning towards the VH238H's 120hz refresh rate and 2MS response time. Which one should I get?
No need to factor in the price, its just a 6 dollar difference
I'm powering them off a MSI PE GTX 670, and plan to use them for gaming.
Thanks for any help!
for gaming i would go with the Asus VH238H
Lower response time 2ms (versus 5ms from the VS239H-P)
By what i've searched none of them is 120hz.
Yes the second one have a IPS panel that is also a pro.
for gaming i would go with the first one, you could search for 120hz display for gaming they are awesome, i use one, and i can't go back to non 120hz displays for games.
