Need some help choosing replacment PSU
srecenvid
4
Hello, i just upgraded my cuda rendering-gaming computer from one EVGA 680 4g FTW to 3xGTX 780TI and moved Gtx 680 in my Hackintosh build. Before i was using HD graphics 4600 GPU on my 4770k cpu with 350w PSU.
When i added gtx 680 to Hackintosh i knew i need new PSU. So i decided to move also my xilence xq 1000w PSU to hackintosh build, while it was loud on full load with 3x780ti but dead silent with only one gtx 680 (thanks to semi-passive cooling). Long story short i ended up with full working hackintosh and missing Psu in my primary build.
I checked a lot reviews and unboxing etc...my final conclusion was i need corsair ax1200i for so i can upgrade to 4th gtx 780ti.
Problems started when i couldn't get any corsair ax1200i...all shops even corsair have written OUT OF STOCK.
Mainly i order from Caseking.de and at the moment they have this PSU in stock:
EVGA SuperNOVA 1300 G2, 80Plus Gold, modular - 1300 Watt
Silverstone SST-ST1500 Strider Series 80Plus silver - 1500 Watt
be quiet! Dark Power Pro 10 modular - 1000 Watt
Enermax Platimax Netzteil, 80Plus Platinum - 1000 Watt
Seasonic P-Series, XP 80 Plus Platinum - 1000 Watt
Antec High Current Pro HCP-1000 Platinum - 1000 Watt
Super Flower Leadex 80Plus Platinum - 1200 Watt
i cant get much information about this PSUs about their Noise level. Please help me.
cuda rendering-gaming computer:
i7 3930k+Corsair H110
Rampage IV extreme BLACK
32Gb Corsair Dominator Platinum
3xEVGA gtx 780 TI SC
Samsung 840 pro 256 + 3 x 3Tb WD red Raid 0
Phanteks Enthoo Primo
Hackintosh:
i7 4770k+Noctua NH-D14
gigabyte GA-Z87X-UD3H
16Gb Corsair Vengeance
1xEvga gtx 680 FTW 4gb
Samsung Evo 250gb
ok prices
EVGA SuperNOVA 1300 G2, 80Plus Gold, modular - 1300 Watt 209,90 EUR
Silverstone SST-ST1500 Strider Series 80Plus silver - 1500 Watt 269,90 EUR
be quiet! Dark Power Pro 10 modular - 1000 Watt 249,90 EUR
Enermax Platimax Netzteil, 80Plus Platinum - 1000 Watt 249,90 EUR
Seasonic P-Series, XP 80 Plus Platinum - 1000 Watt 249,90 EUR
Antec High Current Pro HCP-1000 Platinum - 1000 Watt 239,90 EUR
Super Flower Leadex 80Plus Platinum - 1200 Watt 229,90 EUR
Are all this PSU enough for 4x gtx 780 ti and everything i have in my system?
Seasonic without a question!
Edit: For the price Seasonic would be 20~30% higher but it's #1
http://www.eggxpert.com/forums/thread/323050.aspx
why seasonic? it is enough for 4x gtx 780ti? how noisy is this psu? any personal experience? thanks for fast respond!
Oh! I thought You want to run 3x 780ti if you want to run 4x 780ti then you need 1200~1300W PSU that EVGA Supernova G2 is the best on your list for your system, but if you can find Seasonic X-1250W it would be the best option because I know that Seasonic make strong and silent PSU's!
I can get Seasonic X-Series, XM 80 Plus Gold - 1250 Watt for 279,90 eur...
Yes i was also thinking about EVGA but cant find information about fan noise.
so it ends with EVGA SuperNOVA 1300 G2 and Seasonic X-Series, XM 80 Plus Gold-1250 Watt? what about Enermax Platimax 80Plus Platinum-1500 Watt for 374,90 EUR?
It's top Enermax's PSU but it costs significantly higher, but on 1500W PSU with minimal loads Enermax's fan might spin slower and it means quieter but I'm not sure!
