Need some help connecting monitors
Needshelpalot
OK so, I have an HP desktop with one 1 VGA, no DVI....
I have 2 monitors... Both have VGA & DVI... I am trying to connect the two together, but ive come to realize, you cant do VGA to the computer, then DVI from monitor to monitor (lol bare with me plz)... SO if I bought this, http://www.amazon.com/Plugable-Multiple-Displays-2048x1152-1920x1200/dp/B0038P1TP4/ref=sr_1_1?s=electronics&ie=UTF8&qid=1291868758&sr=1-1
would I be able to go UBS to DVI/VGA, straight to monitor... or will i have to buy a new video card?
Please help, i need dual monitors for work next week
Thanks for reading
its an HP Slimline... not too sure what it has.. i ended up buying that converter on amazon.. i was going to get a new card but i had no clue which would be compatible.. if this adapter doesnt work.. got a video card you can recommend? i dont do gaming so nothing high end..
thanks jaguarskx
