This is my setup:
-Artic Cooler 7 HSF
-AMD Phenom II X4 955 Black Edition
-MSI 870A G54
-G.SKILL F3-12800CL9D-4GBRL Ripjaws PC3-12800 4GB 2X2GB DDR3-1600 CL9-9-9-24 Core i5 1.5V
-XFX Radeon 5770
I had to buy the motherboard again cause I think I fried the VRMs during a "Blend" test in prime95 (was using 19x203 1.45v for the cpu and 8-8-8-24 1.63v for the ram
I've set it to 18.5x with stock voltage, I've run prime 95 (small FFTs) for 4 hours without any errors
After the test was done I noticed my ram was being read as 1333 so i now I've set it to the correct stock settings of 1600 9-9-9-24 (didn't change voltage) and I want to test it again in prime 95 on "Blend"
Is there anything I should be careful about so I don't fry my new mobo?
Should I try changing any settings before I run this new test?
Should I try to up any settings?
How long should a "stability" test be run for?
I'd really like to stay with stock voltage for the cpu and ram (I think that's what fried my last board)
Thank you
-Artic Cooler 7 HSF
-MSI 870A G54
-XFX Radeon 5770
Thank you
