I am at a loss on how to do this i tried using the the oc genie but it iincrese the sped to 4.09 but as soon as i start the primer 95 stress test blend the pc crashes can anyoen walk me through on overclocking this chip thank you
First, don't use an automatic overclocker. Do it all manually. Look up some guides. Basically you just want to go into your bios and find your CPU bus speed and multiplier, start increasing your multiplier to get it to the point you want. You can also increase the voltage to something like 1.4v.
