Need some help picking out pieces for $1000 gaming build pls.
aRodr1guez
219
9
Well title pretty much says it all but I'm looking to build a gaming rig for $1000 and needed some help picking out the rest of the pieces.
What I had in mind so far,
Mobo: ASRock Z77 Pro3: LGA 1155, Intel Z77 Express
CPU: Intel Core i5-3570K
GPU: EVGA 02G-P4-2670-KR GeForce GTX 670
RAM: Crucial Ballistix Tactical 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Profile
I live in the US and usually order my pieces from Newegg.
I still need an optical drive, ssd (if possible just for OS and a few games), hdd (I can use my old one if needed), case, psu.
I'm completely open to any options including changing what I've picked but I rather have intel as well as nvidia. If I can get better performance out an Amd GPU for the price of the 670 then I'm more than welcome to give AMD a try for the first time.
Thanks for the help ahead of time.
aRodr1guez
219
9
Possibly not but would be nice to have the option just incase I plan 2. Don't need a monitor/os/keyboard/mouse.
max_payne
19
Mobo: If you're going to overclock,change the mobo to an ASRock Z77 Extreme4,it overclocks better.
RAM:Try the Corsair Vengeance series,they're usually cheaper.
DVD Drive:Any drive from Sony,Lite-on,Samsung,Asus will be enough.Get the cheapest one.
HDD:Try the Seagate Barracuda.
SSD:If you need performance: Samsung 840 Pro
If you want peace of mind:Crucial m4
boulbox
1,880
81
If you have a microcenter near you, you should really go there and check out the i5 3570k+asrock extreme 4 for around $290 if not, i would make this build.
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($219.98 @ Outlet PC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ Outlet PC)
Motherboard: Asus P8Z77-V LK ATX LGA1155 Motherboard ($119.99 @ Newegg)
Memory: Patriot Gamer 2 Series 8GB (2 x 4GB) DDR3-1600 Memory ($47.98 @ NCIX US)
Storage: Sandisk Ultra Plus 128GB 2.5" Solid State Disk ($97.49 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($66.98 @ Outlet PC)
Video Card: EVGA GeForce GTX 670 2GB Video Card ($369.99 @ NCIX US)
Case: Corsair 200R ATX Mid Tower Case ($49.99 @ Newegg)
Power Supply: Corsair Enthusiast 650W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($78.50 @ Newegg)
Optical Drive: LG GH24NS95 DVD/CD Writer ($17.98 @ Outlet PC)
Total: $1098.86
(Generated by PCPartPicker 2013-04-19 23:50 EDT-0400)
$100 over. if you can't get that extra $100, take out the SSD or lower the GPU to a 660 ti
aRodr1guez
219
9
Thanks for the reply. I went ahead and switched out something's and put this together
PCPartPicker part list: http://pcpartpicker.com/p/RPt1
Price breakdown by merchant: http://pcpartpicker.com/p/RPt1/by_merchant/
Benchmarks: http://pcpartpicker.com/p/RPt1/benchmarks/
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($189.99 @ Microcenter)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($133.00 @ Amazon)
Storage: Samsung 840 Series 120GB 2.5" Solid State Disk ($89.99 @ NCIX US)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($67.97 @ Outlet PC)
Case: Corsair 300R ATX Mid Tower Case ($59.99 @ Microcenter)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($17.98 @ Outlet PC)
Total: $1085.37
(Generated by PCPartPicker 2013-04-20 01:24 EDT-0400)
How does it look? Still open to any changes that would be best.
boulbox
1,880
81
Looks good, would personally grab the Sandisk ultra instead because it uses MLC nand which is better than the TLC(TLC dies faster but you can use it for a good amount of time still)
realchaos
Video Card: Sapphire Radeon HD 7950 3GB Video Card ($275.66 @ Newegg)
Power Supply: Corsair CX 600W 80 PLUS Bronze Certified ATX12V Power Supply ($59.99 @ Microcenter)
Total: $959.52
(Generated by PCPartPicker 2013-04-20 01:38 EDT-0400)
-cheaper motherboard, but just as good
-Cheaper psu, plenty of watts for upgrades, semi-modular as well
-The 7950 will provide great bang/buck. It's a really good, and cheap, 7950 that can compete wit the gtx670.
aRodr1guez
219
9
If I choose to stick with the 670 will that PSU be enough?
boulbox
1,880
81
CX series is "OK" for now. It is one of the brands i trust but the PSU itself, i don't really like at all. I usually have them for lower end budget builds with the 400-500W being around $30 but i suggest getting a better PSU if you want to SLI the 670
realchaos
Actually, if you're planning to just run a single gtx670 (and don't plan to SLI) grab the 500w version instead. It'll be cheaper and still have headroom for overclocking since nvidia cards don't take up as much watts as amd cards.
CX isn't a great psu, I know. I never recommended them before, but then the xfx psu was raising in price while the cx stayed cheap. Even though the quality isn't that great, you can't ask for much from the price.
burritobob
1,082
66
$20 cheaper than the 670 build but about 10% faster.
Video Card: Gigabyte Radeon HD 7970 3GB Video Card ($389.99 @ NCIX US)
Case: Cooler Master HAF 912 ATX Mid Tower Case ($55.99 @ NCIX US)
Power Supply: Corsair CX 500W 80 PLUS Bronze Certified ATX12V Power Supply ($49.99 @ Newegg)
Optical Drive: LG GH24NS95 DVD/CD Writer ($15.30 @ Newegg)
Total: $1057.17
Similar threads
