Need some help with 24 pin cable
Blaze1983
18
i bought the alchemy 2.0 csr series cables to install in my pc, in the box there is 2 different 24pin ATX cables (one has RMX/RMI stick on)
i have a msi z97 gaming 7 mo bo, coursair ax860 power supply.
I cant seem to get either cable to work, only the one with RMI sticker on fits but pc wont power on, if i place old cable back in it all works. Can anyone advise me what cable i would need?
(pic of cable that works)
Like said above the AX860 was made by seasonic, the AX860i was made by CWT. They are different psu's not even made...
So you have a coursair ax860 and you bought RMX/RMI alchemy 2.0 csr series cables?
You need to by cables that match your PSU. So if its RMX/RMI or CSR or whatever they won't work. Needs to be AX compatible because the pins are generally arraigned differently. The AX is a sesonic psu re-branded.
Compatibility:
Alchemy 2.0 - CSR
AXi Series: AX1500i, AX1200i, AX860i, AX760i
HXi Series: HX1200i, HX1000i, HX850i, HX750i
RM Series: RM1000, RM850, RM750, RM650, RM550, RM450
RMi Series: RM1000i, RM850i, RM750i, RM650i
RMx Series: RM1000x, RM850x, RM750x, RM650x, RM550x
CS-M Series: CS850M, CS750M, CS650M, CS550M
TX-M Series: TX850M, TX750M, TX650M, TX550M
CX-M Series: CX750M, CX600M, CX500M, CX430M
it says this on the store page.
ax860i my psu says ax860, and i called overclockers to check if the "i" made a diff they said was just a power rating or something.....
so will this not work? need to get ax860 not ax860i
Like said above the AX860 was made by seasonic, the AX860i was made by CWT. They are different psu's not even made by the same company, I would assume those cables aren't compatible sorry to say.
I looked through all the corsair cable kits on that site they did not seem to have them. I found some on amazon UK through some third party sellers, you may want to have a look at them.
https://www.amazon.co.uk/Corsair-COR-Type3-Sleeved-Cable/dp/B00BJMDIDY/ref=sr_1_7?ie=UTF8&qid=1466467875&sr=8-7&keywords=ax860+cables
Latest posts
