I picked up this card recently and unfortunately when I got it home I found out that theres NO documentation with it at all.
There is 1 mini CD that has 2 folders on it and thats it. To make matters worse, when you run the programs, they aren't in English. I ran both programs and I think they installed OK but I can't say for sure since nothing is in English. The problem I'm having is that even though I installed the software, the USB ports are only giving me USB 2.0 speeds. (Yes I used a USB 3.0 device to test it)
The company name is about the only solid info I have for this thing. Renesas. It has 2 USB 3.0 ports and thats about it.
The 2 folders on the CD are labelled "302808" and "driver".
The name of the file in the "302808" folder is "F302808FWUP1.exe"
The name of the file in the "driver" folder is "USB3_allOS_2.1.16.0_NEC_PV.exe"
Does anyone out there know where I need to go to get updated drivers/firmware, and maybe some English instructions? Or maybe, does anyone know whats causing this problem?
Thanks!
Thanks!
