It came today and I've never used it (or any other thermal grease, I always use the pads that are attached to HSF's). I decided to use it on the 2.4G celery(as a test), heres the problem my fan now spins at 1600 Rpm (used to be 2200rpm) the chip goes to 60C and the fan goes to 3500 Rpm and never lowers. Its an OEM comp and Speedfan wont let me set the Fan Rpm to 2200. I made sure it was a thin layer, cant tell if its transperant becuase silver on a silver heat spreader doesnt help. Could I have put too much or not enough?
Any opinions are welcome. Its a POS anyway thats why I used it as a test rat.
Temps before 50C idle / 57C Load
Temps now 52C idle / 60C Load
Not making me comfortable about using AS5 on my AMD X2.
