Hey this question has probably been thrown around a million times before. But Im having trouble finding a decent answer myself and need some help from a community of fine computer using folk like yourselves.
Basically Im after a decent gaming mouse. Ive used a g5 a long while ago and loved it then.. so I tried a g500 which I simply cant get used to and bought an mx518 which just doesnt feel right either. Ive been using a razer naga for a while as I used to play MMO's and Ive found that I dont palm grip like I used to with a logitech g5 I now fingertip grip....
So the problem im facing is researching decent mice as there is the whole optical vs laser debate... and well I have huge hands... when I say that... the razer naga sits along my fingers without even hitting my palm. And since my grips changed with the naga I cant seem to get used to the g500 or similar.
Im considering getting a Razer deathadder BE, or a logitech g9x possibly even something entirely different. I play games casually now and use the computer for everyday things so I wouldnt be able to tell you the difference between optical or laser...
Im not a razer fanboy... and Ive had a deathadder before when I used to palm grip and it just gave me insanely bad wrist cramps. Although ive found the razer software much easier to use than logitech so there are pros and cons for both....
Any advice guys? what would you recommend?
