Need Some Help With Laptop Problems
Jaberzz
Commendable
Apr 25, 2016
Hey Guys. I have a Dell Precision M6600. It has the i7 2760qm Quad Core and the Quadro 3000m. I just got it today and when I put Windows 10, Minecraft, and Black Ops 1 on it, everything ran as it should. Minecraft ran Flawlessly and Black Ops ran good on Low-Medium Settings. Normal, Right? Well Now after installing the rest of the things I need and adjusting some more settings, everything runs slow. Minecraft gets 10-20 FPS and Black Ops is laggy on the lowest settings. I've tried disabling SpeedStep, Running Diagnostics (Which Passed) and resetting the BIOS. I have the newest version of every Driver installed so I have no idea what's going on. It's almost like the CPU isn't using all of it's cores. I have no idea what I could have done to make it slow because it was running so good. Any help is appreciated. I should mention I have a 64 GB SSD and 8 GB of Ram. Also, I just realized it runs a bit better on the battery which is weird. I also just realized it has a 3rd party power adapter.
If you are running with the battery removed while on wall power test it with battery in the system.
You also said it worked fine till you installed some things and "adjusted some settings", undo what you did and try it again.
